User Data Limitations of the Rino 750 Series
When sending or creating files for a Rino® 750 series handheld, keep in mind the following limitations:
  • 2,000 GPX files
  • 10,000 waypoints
  • No limit on geocaches (outside of max number of GPX  files supported and memory available)
  • 250 routes, 250 points per route
  • 200 saved tracks
  • 2,000 archive tracks
  • 20,000 points per track
  • 100 custom map tiles
  • 50 contacts with 2,000 track points each
  • 250 BirdsEye Imagery files
  • Mapping segments 15,0001
Each GPX file can contain a mixture of waypoints, geocaches, routes and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on device.
When utilizing routes, only 50 points can be used for on road navigation.
1See Related for more information.
Related
