Showing Active Track Data on the Map Page
If you find the active track log not showing on the Map page, the track log recording method needs to be modified. To find the recording method setting:
- Go to the Main Menu
- Select Setup
- Select Tracks
The track log setting will appear at the top of the screen. If the setting is set to Record, Do Not Show or Do Not Record, it will need to be changed to Record, Show on Map.
If you wish to see the active track log on the map, but do not want to continue recording new tracks simply save the active track as a saved track. Then, set this saved track to show on map. For information on saving and viewing tracks, refer to your device's owner's manual. To find the owner's manual, if you identified the specific device you are using select manuals on the left of the page, otherwise see the Related Content below.
