Using the Dual Orientation Display on an Automotive Device
Devices with a dual-orientation display can be used either vertically (portrait) or horizontally (landscape).
Most dual oriented devices are changed manually in the display settings. Some devices change automatically when tilting the device vertically or horizontally.
Devices with Manual Dual Orientation Display
Dual orientation display devices listed below can be manually changed from a horizontal to a vertical display.
To Change the Display Orientation:
- Touch Settings
- Touch Display
- Touch Orientation
- Touch the desired setting
- Touch Save
The screen will now be set in the desired orientation. Repeat the above steps to change the orientation as needed.
BMW GPS Navigators
- BMW Motorrad Navigator V
- BMW Motorrad Navigator VI
dēzl™ GPS Navigator
- dēzl™ 580 LMT-S GPS navigator
Garmin Drive™ 40/50/60 GPS Navigators
- Garmin Drive™ 40 GPS navigator
- Garmin Drive™ 5 | Garmin Drive™ 5LM EX | Garmin Drive™ 5LMT GPS navigators
- Garmin Drive™ 50 | Garmin Drive™ 50LM | Garmin Drive™ 50LMT GPS navigators
- Garmin Drive™ 51 | Garmin Drive™ 51EX | Garmin Drive™ 51LM GPS navigators
- Garmin Drive™ 6LM EX GPS navigator
- Garmin Drive™ 60LM | Garmin Drive™ 60LMT GPS navigators
- Garmin Drive™ 61 | Garmin Drive™ 61EX | Garmin Drive™ 61LMT-S GPS navigators
Garmin DriveSmart™ 50/60 GPS Navigators
- Avis Garmin DriveSmart™ 50 GPS navigator
- Garmin DriveSmart™ 5 GPS navigator
- Garmin DriveSmart™ 50LMTHD GPS navigator
- Garmin DriveSmart™ 51LMT-S GPS navigator
- Garmin DriveSmart™ 60LMT GPS navigator
nüvi® 2405 GPS Navigators
- nüvi® 2455 | nüvi® 2475 | nüvi® 2495 GPS navigators
nüvi® 2407 GPS Navigators
- nüvi® 2457 | nüvi® 2497 GPS navigators
nüvi® 2408 GPS Navigators
- nüvi® 2468 | nüvi® 2498 GPS navigators
nüvi® 2505 GPS Navigators
- nüvi® 2555 | nüvi® 2595 GPS navigators
nüvi® 2507 GPS Navigators
- nüvi® 2557 | nüvi® 2577 | nüvi® 2597 GPS navigators
nüvi® 2508 GPS Navigators
- nüvi® 2558 | nüvi® 2598 GPS navigators
nüvi® 2509 GPS Navigators
- nüvi® 2539 | nüvi® 2559 | nüvi® 2589 | nüvi® 2599 GPS navigators
nüvi® 2609 GPS Navigators
- nüvi® 2639 | nüvi® 2689 | nüvi® 2699 GPS navigators
nüvi® 50/60 GPS Navigators
- nüvi® 55 | nüvi® 56 | nüvi® 57 | nüvi® 58 | nüvi® 65 | nüvi® 66 | nüvi® 67 | nüvi® 68 GPS navigators
zūmo® GPS Navigators
- Can-Am Spyder zūmo® 590 GPS navigator
- Harley Davidson Roadtech zūmo® 590 GPS navigator
- zūmo® 590 | zūmo® 595 GPS navigators
Devices with Automatic Dual Orientation Display
Automatic dual oriented display devices use an accelerometer to detect when the device has been rotated and will automatically adjust the display accordingly.
Note: The nüvi® 2360 contains a 3-axis electronic compass to detect when the device has been rotated and automatically adjusts the display. The electronic compass will also detect which direction you're facing and point the position indicator accordingly.
These devices do not have a display setting to change the orientation manually. All versions of devices listed below are included in the GPS Navigator (i.e. nüvi® 3790T, nüvi® 3790LMT).
BMW GPS Navigators
- BMW nüvi® 3490 | BMW nüvi® 3790 GPS navigators
Garmin DriveLuxe™ 50 GPS Navigators
- Garmin DriveLuxe™ 50LMTHD | Garmin DriveLuxe™ 51 GPS navigators
nüvi® 2300/3400/3500 GPS Navigators
- nüvi® 2360 |nüvi® 3450 |nüvi® 3490 |nüvi® 3550 | nüvi® 3580 | nüvi® 3590 GPS navigators
nüvi® 3507/3508 GPS Navigators
- nüvi® 3587 | nüvi® 3597 | nüvi® 3598 GPS navigators
nüvi® 3700 GPS Navigators
- nüvi® 3750 | nüvi® 3760 | nüvi® 3790 GPS navigators
Devices with Manual and Automatic Dual Orientation Display
Manual dual orientation display devices can be manually changed from a Portrait or Landscape display to an automatic.
- Touch Settings
- Touch Display
- Touch Orientation
- Select an Orientation option
- Touch Save
Garmin DriveSmart 86 with Amazon Alexa
- Garmin DriveSmart™ 86 with Amazon Alexa GPS navigator
Tread GPS Navigators
- Tread® | Tread® - Base Edition GPS navigators
zūmo GPS Navigators
- zūmo® XT | zūmo® XT2 GPS navigators
See Automotive Devices without the Dual Orientation Display Feature for a list of devices without this feature.
