Troubleshooting a Bluetooth or dēzl™ App Issue with the Instinct® 2: dēzl™ Edition
Your Instinct® 2: dēzl™ Edition watch uses Bluetooth technology to connect with your mobile phone.
An Issue With the Bluetooth Connection Between the Two can Cause any of the Following Issues:
  • Watch and phone will not find one another.
  • Watch and phone encounter problems during the pairing process.
  • The pairing process is successful, but devices do not maintain a Bluetooth connection.
  • dēzl™ App features like Pilot Flying J myRewards and My Love's Rewards are not displaying on the watch.
Note: It is not possible to troubleshoot a Bluetooth or  dēzl™ App issue while on an active phone call, as it may interfere with certain features.
We Suggest Troubleshooting in This Order for Bluetooth or dēzl™ App Issues:
1. Phone Requirements
Ensure your Phone Meets System Requirements for the dēzl™ App:
Go to the dēzl™ App and select either App Store or Google Play to find the current requirements. It is necessary to use a phone which meets these requirements.
Verify your Phone has the Required Permissions Enabled:
See Phone Permissions Required to Use the dēzl™ App and Garmin Drive™ App for more information.
Check for Updates to the Phone’s Operating System:
To Check for Updates on iOS:
(Note: These steps will vary depending on the phone and OS combination)
  1. Open the phone's Settings menu
  2. Touch General
  3. Touch Software Update
To Check for Updates on Android:
1. Touch the Apps menu (some phones skip this step)
Red box around apps icon
2. Touch Settings or the Gear icon
Red box around the Settings icon
3. Touch About Phone (some phones skip this step)
4. Touch Software Update or System Updates (you may need to scroll down the page)
Red box around Software update
5. Touch Download and install or Check for system updates (some phones skip this step)
Red box around Download and install option
6. Touch Download or Yes if updates are available
7. Touch Install Now
The phone should now check for and apply any necessary system updates.
2. Software Updates
Check for Updates to the Software of the watch:
See Updating  the Software Using the Garmin Connect App.
Check for Updates to the dēzl™ App:
Search for the dēzl™ app in the Google Play or App Store to check for updates and apply them, if available.
The installed version number of the dēzl™ App can be found on the phone itself if the app will not launch.
To Locate the Software Version of the dēzl™ App:
iOS:
  2. Touch General
  3. Touch iPhone Storage
  4. Touch dēzl™
Android Version 7 or Older:
  2. Touch Apps
  3. Touch dēzl™
Android Version 8 or Newer:
  2. Touch Apps or Apps & Notifications
  3. Touch App Info (Some phones skip this step)
  4. Touch dēzl™
The current version of the dēzl™ App should be displayed here.
3. Restart Phone and Watch
Be sure to completely restart your phone before proceeding.
See your phone's documentation for instructions on fully restarting your phone.
To reboot your watch, hold the CTRL button until the watch turns off. Then hold CTRL to turn on the watch.
4. Re-Pair by Forgetting the watch from Phone's Bluetooth Settings
Clear the watch From the Phone’s Pairing History:
Steps for clearing pairing history on the phone can vary by make/model. See your phone's manual or manufacturer if unsure how to clear your phone's pairing history. The steps below apply to most iOS and Android phones:
To Clear Pairing History on an iPhone:
  2. Touch Bluetooth
  3. Touch the info button ("i" icon) next to the paired Garmin Device
  4. Touch “Forget this device”
To Clear Pairing History on an Android phone:
  2. Touch Connections (some phones skip this step)
  3. Touch Bluetooth
  4. Touch the gear icon next to your listed Garmin Device
    • Select the name of the listed Garmin Device instead on some Android phones
  5. Touch Forget/Unpair
The Garmin Device will now be cleared from your phone's pairing history.
To Pair the dēzl™ App and Your Instinct® 2 dēzl™ Edition:
See Installing the dēzl™ App for instructions.
5. Clear App Cache
Clear the dēzl™ App’s Temporary Cache Files From the Phone:
Clearing the cache can remove any problematic files from the phone's temporary storage.
To Clear the Cache:
Most iPhones:
  1. Double-press the iPhone's home button
  2. A list of currently running apps will appear
  3. Swipe up on the dēzl™ App to remove it from the list and close it
iPhone X and Newer:
  1. Swipe up from the bottom of the screen and pause
  2. Swipe up on the dēzl™ App
Android:
  2. Touch Storage (some phones skip this step)
  3. Touch Other Apps or Apps
  4. Touch dēzl™
  5. Touch Storage (some phones skip this step)
  6. Touch Clear Cache
The temporary files should now be cleared and the app can be re-opened.
6. Uninstall and Reinstall the dēzl™ App
To Uninstall the dēzl™ App on Android:
2. Touch Apps
3. Touch the dēzl™ App
4. Touch Uninstall
To Uninstall the dēzl™ App on iOS:
1. Touch and hold the dēzl™ App icon
2. Touch the X that appears in the corner of the icon
It can be re-downloaded from the phone's Google Play Store/iTunes App Store.
