Troubleshooting 100% power on left or right side
When using the Vector system, it may report 100% Left or Right power or display 'Left Power Sensor Missing' at times. This is caused by one pedal no longer transmitting a signal to your compatible device. Troubleshooting steps are available to resolve this including:
- Ensure pedal pod cables are connected
- Ensure battery doors are flush and locked
- Replace batteries in pedal pods
- Remove pedal pods/swap left and right sides
- Update pedals with Vector Updater
If you have never been able to pair your Vector system it may be that your crank arms are incompatible with this system. Please check our Related Content to see if your crank arms will work with Vector.
