Pairing an inReach Messenger With a Smartphone
NOTE: This article is intended for users who have already activated an inReach® subscription for their inReach Messenger. If you have not yet activated an inReach subscription for the device, see - Pairing Your Phone and Activating an inReach Messenger.
Garmin Messenger™ is an Android and iOS mobile application that optimizes inReach messaging to use the cellular connection of your compatible smartphone when it is available, then switches to 100% global Iridium satellite link with a compatible inReach device when you go beyond available cellular coverage range. It also allows you to control and customize certain functions and settings for the connected inReach device.
The inReach Messenger can be paired with one smartphone at a time.
1. Setting up the Garmin Messenger App
null
2. Pairing the inReach Messenger
- In the Garmin Messenger app, select the profile icon or
in the top left.
- Select Pair.
- Allow any app permissions when prompted.
- Enable pairing mode on the inReach Messenger:
- If necessary, press and hold
to reach the home page.
- Press
or
to scroll through the main menu and select SETTINGS
- Select Phone
- Select Pair Device.
- In the Garmin Messenger app, select Connect It and enter the 6 digit code from the inReach Messenger when prompted.
