3D Terrain View
3D Terrain View displays map contours at low zoom levels, giving you a realistic perspective of the terrain in available areas. See an example of what 3D Terrain View looks like at the bottom of the article.
To Disable 3D Terrain View:
  1. Touch Settings
  2. Touch Map Display
  3. Touch Map Layers
  4. Uncheck the box next to 3D Terrain
  5. Touch Save or OK
With the 3D Terrain map layer unchecked, the 3D Terrain mapping will be disabled. Place a check mark to re-enable the 3D Terrain mapping.
