Remove Running Dynamics Pod Reminder
After completing an activity while using the Running Dynamics Pod (RD Pod) compatible devices will provide a reminder alert to remove the RD Pod from the clothing. This message can be acknowledged each time or you have the option to chose Do No Show Again.
Once this message is dismissed to not show again, the only way for this alert to be visible is for the device to be restored to default settings. Choosing to restore the device to its default settings will erase all settings from the device and require you to go through the setup process again.  For details on how to perform this reset refer to your Owner's Manual.
