Settings That Improve the Distance and Speed Accuracy of the fēnix 7 and fēnix 7 Pro Watches
There are many factors that contribute to incorrect speed and distance on an outdoor watch. Some are outside of your control, such as GPS Drift and environmental factors. However, there are several changes you can make to the settings of your watch that can improve the data captured during an activity.
Recording Methods
Many of Garmin's outdoor watches offer the ability to change the recording method, with a choice between Smart Recording and Every Second. This setting refers to the interval at which GPS data is recorded during an activity. Smart Recording is the default setting due to the balance it achieves in detail and battery consumption, but enabling Every Second recording can improve speed and distance accuracy.
Smart Recording vs. Every Second
Smart Recording
  • Smart Recording saves GPS points when changes in direction, speed, heart rate or elevation are detected. Smart Recording is the default setting of Garmin's watches for the balance it achieves in detail and battery consumption.
Every Second Recording
  • Every Second recording will record a GPS point once per a second, regardless of direction, speed, heart rate or elevation. Every Second recording will produce highly detailed tracks of your activities. A more detailed track will lead to more accurate speed and distance data.
Example of Smart Recording vs. Every Second Recording
  • The upper track represents Smart Recording while the lower track represents Every Second recording. You can see that Every Second recording creates a more smooth track line, and picks up small changes that Smart Recording does not.
Smart Recorded Track versus Every Second Recorded Track
Changing Recording Methods
  1. Press and hold UP/MENU to access the Main Menu.
  2. Scroll to Settings and select System.
  3. Select Data Recording.
  4. Select Frequency.
  5. Select Every Second.
3D Speed and 3D Distance
The 3D Speed and 3D Distance features change the way outdoor watches read speed and distance by taking into account elevation changes when calculating distance and speed.
  • 3D Speed – Calculates speed using both the elevation change and horizontal movement over ground.
  • 3D Distance – Calculates the distance traveled using both elevation change and horizontal movement over ground.
Enabling 3D Speed and 3D Distance improves speed and distance accuracy when doing activities with moderate to high elevation changes.
  2. Scroll to Settings and select Activities & Apps.
  3. Select a specific activity type, such as Run.
  4. Select (Activity Name) Settings.
  5. Toggle on 3D Speed and/or 3D Distance.
Once these features are enabled, the watch will calculate speed and distance using 3D Speed and 3D Distance.
Multi-Band GPS (Sapphire Solar Editions and fēnix 7 Pro Watches Only)
The fēnix 7 Sapphire Solar watches and the fēnix 7 Pro watches all feature "Multi-Band" or Dual-frequency GNSS (Global Navigation Satellite System) capability, which can help to improve speed and distance accuracy when environmental factors like tall buildings or trees are difficult to avoid.
Enabling Multi-Band GPS
  1. Press START to view the activity list.
  2. Select an outdoor activity profile.
  3. Press UP to access Options.
  4. Select the activity settings.
  5. Select Satellites.
  6. Select All Systems + Multi-Band.
For more information about Multi-Band GPS, refer to What is Dual Frequency/Multi-Band GPS?.
null
Related
