Purpose of Wi-Fi on Outdoor Handhelds
Connected features are available for compatible outdoor handhelds when you connect the device to a wireless network or a compatible smartphone using Bluetooth technology. Some features, like BirdsEye Direct, specifically require a Wi-Fi connection, while other features may also work when the handheld is paired with the Garmin Connect app on your smartphone.
Compatible Devices
The following devices have both Wi-Fi and Bluetooth connectivity.
GPSMAP 276Cx
GPSMAP 66 Series
GPSMAP 67 Series
GPSMAP 86 Series
Montana 700 Series
Oregon 700 Series
NOTE: Available features will vary by device. Refer to "Connected Features" in your owner's manual to confirm which of these features your device has.
Connected Features That Can Be Used With Wi-Fi
EPO Downloads Allows you to download an extended prediction orbit file to quickly locate GPS satellites and reduce the time it takes to get an initial GPS fix using the Garmin Connect app or when connected to a Wi‑Fi network.
BirdsEye Direct Allows you to download BirdsEye Satellite Imagery directly to your device when connected to a Wi‑Fi network.
Live Geocache Data Provides paid or subscription-free services to view live geocache data from www.geocaching.com using the Garmin Connect app or when connected to a Wi‑Fi network.
Software Updates Allows you to receive updates for your device software using the Garmin Connect app or when connected to a Wi‑Fi network.
Weather Allows you to view current weather conditions and weather forecasts using the Garmin Connect app or when connected to a Wi‑Fi network.
