TR-1 Gladiator Autopilot not tuned even after performing the Autotune procedure
If the TR-1 Gladiator appears to not be tuned correctly even after a successful Autotune, please ensure that once the Autotune procedure is completed successfully that it is downloaded into the permanent memory of the TR-1 Gladiator. To download the successful Autotune into the permanent memory of the TR-1 Gladiator Autopilot, please perform the following:
- Press the Setup button to ensure the LED is On
- Press and Hold the GPS [Select Load] button*
- While still holding down the [Select Load] button, press and release the [Deckmount] On/Off button quickly
- Release the [Select Load] button
* The [Load] LED should illuminate on the handheld.
The Autotune will now be stored in the internal memory of the TR-1 Gladiator and the autopilot should perform correctly the next time it is engaged.
