New SD Card Gives Error With Varia RCT715
A flashing yellow camera status LED on your Varia RCT715 and an SD card error in the Varia app after installing a new SD card, means that you will need to reformat the SD card using the Varia app.
NOTE: Only reformat the SD card using the Varia app. Using a computer to reformat the card may result in an incompatible format.
Reformat the SD Card in The Varia App
Open the Varia app.
Power on your RCT715 so it pairs with the app.
Select the RCT715 icon with the green dot at the top of the page.
Select Storage > Erase & Reformat Card.
Select Erase & Format > Erase & Format. This will erase all data on the SD card! This action cannot be undone.
