Why Does the Depth on the Cross Hairs Stay the Same When Water Level is Changed?
For quick visibility of objects on the chart, the cross hairs display an object info box. This data is taken directly from the chart database and is static. It will not change with any adjustment to the Water Level in your Map Options. This quick object information may be found also by tapping on the question mark icon.
