Using Dash Cam Video Sync to Connect/Pair Multiple Garmin Dash Cams with the Garmin Drive App
Using Dash Cam Video Sync allows any combination of up to 4 of the Garmin Dash Cams below to be paired simultaneously with the Garmin Drive™ app. This allows you to install multiple dash cameras in the same vehicle, such as front and rear cameras, and create composite picture-in-picture videos from the simultaneous recordings. The Garmin Dash Cam™ Tandem has two lenses. This allows you to have up to eight lenses recording video at the same time if you have four Garmin Dash Cam Tandems.
  • Garmin Dash Cam™ 46
  • Garmin Dash Cam™ 47
  • Garmin Dash Cam™ 56
  • Garmin Dash Cam™ 57
  • Garmin Dash Cam™ 66W
  • Garmin Dash Cam™ 67W
  • Garmin Dash Cam™ Live
  • Garmin Dash Cam™ Mini
  • Garmin Dash Cam™ Mini 2
  • Garmin Dash Cam™ Tandem
This Video Provides a Quick Look at Dash Cam Video Sync:
For instructions on pairing multiple cameras in the Garmin Drive app, see the Pairing with Your Smartphone section in the owner’s manual for the Dash Cam.
See Troubleshooting A Garmin Drive App Issue with a Garmin Dash Cam if there are issues with pairing your dash cam(s).
Related
