Yamaha Command Link Plus Fuel Data Does Not Appear on the Gramin NMEA 2000 Network
If the NMEA 2000 information from the Yamaha engines are not being displayed on the NMEA 2000 network, check that the correct Yamaha NMEA 2000 gateway is being used.
Yamaha has a Command Link Plus version of its gauges. The Command Link Plus gauges use a different NMEA 2000 Gateway then the older gauges. The new gauges use the NMEA 2000 gateway with a part number of MAR-GTWAY-KT-00.
To display the fuel data, go to the display menu under fuel and change the setting for data output. Once the data output is changed the fuel information will be available.
