Open the Garmin Connect app.
Access the menu by selecting More (bottom right).
Select Settings.
Select Phone Permissions.
Select Manage Permissions.
Select Permissions.
Select Location.
Select Allow all the time.
If "Allow all the time" is not an available option, toggle Location On.
For optimal results, enable Precise Location if available.
Power your Android phone off and back on.
Power your Garmin device off and back on.
Sync your device.
Weather Widget Displays Wrong Information on My Garmin Device
Review each section of this FAQ which addresses the most common issues and questions related to weather information on your Garmin® device.
I See One of the Following Messages When Viewing the Weather Widget
Widget displays an exclamation icon
Weather data is not available
Waiting for data
- This likely means you are located a long distance from the nearest weather station. This results in no weather information being displayed for your current area.
Common Troubleshooting Steps
Try each step below which should resolve most issues described above.
Power your Phone and Garmin device off, then back on.
Confirm the Garmin device is paired and connected to the phone through the Garmin Connect™ app.
For GPS capable Garmin devices, start an outdoor activity and briefly step outdoors to acquire GPS signal.
For iOS devices, make sure the Garmin Connect app is open and/or running in the background. Force closing the app will result in missing weather data.
You should also check your location permissions. Select an option below to reveal steps on how to enable Location permissions.
Open the Settings app on your iOS device.
Select Privacy & Security.
Select Location Services.
Toggle on if needed.
Select the Garmin 'Connect' app.
Ensure Allow Location Access is set to Always.
For optimal results, enable Precise Location.
Power your iOS device off and back on.
Sync your device.
From the Garmin Connect app, we allow you to choose between your phone's current location or from a fixed location that you choose from a map within the app.
Select Settings.
Select User Settings.
Select Weather Location.
From here you will choose from either your phone's location or a fixed location.
NOTE: Devices that display a location in the weather widget will display the location of the weather reporting station.
Some models will require you to change temperature metrics in the Garmin Connect app only and some models will need you to update Metrics in the app as well as on the watch. For specific details refer to your owner's manual.
Select Settings.
Select Measurement Units.
Set to Statute, Metric, or Statute UK.
Steps may vary based on model. See your owner's manual for specific steps.
Access the menu on your device.
Select
Settings.
Select System.
Select Units.
Select Temperature.
Select Fahrenheit or Celsius.
Widget Gallery
When selecting the Weather Widget, scroll through the available data screens to see additional weather data. Below are some examples of what data may be available.
NOTE: Air Quality data will display on compatible devices that are located in the continental United States. Outside of the U.S., Air Quality data may not be available.
