O-Ring Replacement Instructions for NEO Series Smart Trainers
If you are experiencing a grunting or a whump-whump type of sound coming from your Tacx NEO series trainer while you ride you will likely need to replace the O-ring found behind the NEO disc. This FAQ is designed to help you complete steps for the following Tacx smart trainers:
  • Tacx® NEO
  • Tacx® NEO 2
  • Tacx® NEO 2T
Tools Required:
  • S0057 O-ring
  • NEO Disc Extractor
  • 4mm and 5mm Allen Key
  • Adjustable Wrench
O-Ring Replacement Instructions:
  1. Remove the Disc using the NEO Disc Extractor.
    • See first 1:30 of video below
  2. Once the disc has been removed,  you will have access to the O-ring located at the base of the axle hub. The O-ring is circled in the photo below in red.
    • NEO Users: place the O-ring in front of the preinstalled ring
    • NEO 2 and 2T Users: remove existing O-ring and replace it with the new O-ring
      Photo showing the location of the O-ring in the Neo and Neo 2T trainers
  3. To further prevent noise, ensure the size 4 Allen bolts shown below are tightened to 10 Nm.
    • 6 bolts on the internal coil housing
      6 bolts on internal coil housing
    • 6 bolts on the trainer's non-drive side
      6 Bolts on Non drive side of NEO
  4. Reinstall the disc.
    • See 1:30 - 2:35 of video below.
  5. Tighten the 6 bolts on the disc to 10Nm.
    tighten the 6 bolts on disc
How to Remove The NEO Disc
