Purchasing and Replacing QuickFit 20mm Spring Bars for Select Garmin Watches
Garmin® watch band pins (or spring bars) are designed to work with our QuickFit® bands and to keep your watch band secured to the watch.
If you need replacement band pins because your pin is bent, or for another reason, they can be purchased on Garmin.com.
These new band pins are only compatible with the following watches:
  • Descent™ Mk2S watch
  • epix™ Pro (Gen 2) - Standard Edition - 42mm | epix™ Pro (Gen 2) - Sapphire Edition - 42mm watches
  • fēnix® 6S - Standard Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition watches
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition watches
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition watches
null
