I’m Having an Issue Using the Spotify App on My Watch
If your Garmin watch is running out of storage space for downloaded music, the Spotify Connect IQ app on your watch may stop functioning properly. Issues can include:
- The Spotify Connect IQ app crashes
- Music fails to sync to the watch
- Music fails to play on the watch
We are working to solve these issues through a watch software update. A temporary fix can be used by uninstalling and reinstalling the Spotify Connect IQ app on the watch:
Change the music provider on the watch from “Spotify” to “Control Phone”.
Select option below to reveal instructions:Non-Touchscreen Watches (D2 Delta Series, fenix 5 Plus Series, Forerunner 245 Music, 645 Music, and 945, Marq series)
On the watch, press and hold the Down Key (the music shortcut key).
Press and hold Menu key to access settings
Select Music Providers
Select Control Phone
Touchscreen Watches (vivoactive 3 Music Series)
Swipe the screen on the watch to the Music Widget
Press and hold screen to access settings
Select Control Music on Phone
Uninstall the Spotify Connect IQ app using one of the options below.
Select option below below to reveal instructions:Garmin Connect app
- Open Garmin Connect App
- Android: Select
(upper left)
iOS: Select More (bottom right)
- Android: Select
Select Garmin Devices
Select the device
Select Music
Select Spotify
- Touch Uninstall
iOS- Touch
then touch Uninstall
Sync the watch
Connect IQ Store app
Open Connect IQ Store app
Select
- Select Manage Device
If you have more than one Garmin device you can switch the device by touching Devices
Select My Music
Select Spotify
Tap Uninstall
- Sync the watch
Garmin Express
Connect device to computer via USB cable
Open Garmin Express
Select the device
Select Music
Select Music Apps
Select the X next to Spotify
Sync the watch
Reinstall the Spotify Connect IQ app using one of the options below.
Select option below to reveal instructions:Garmin Connect app
- Android: Select
(upper left)
- Android: Select
Select the device
Select Music
Select Spotify
Touch Install
Sync the watch
Select
Select My Music
Select Spotify
Tap Install
- Sync the watch
Garmin Express
Open Garmin Express
Select the device
Select Music
Select Music Apps
Select
next to Spotify
Sync the watch
Log back into Spotify to set up the Spotify Connect IQ app again:
- Press and hold Menu key to access settings
- Select Music Providers
- Select Spotify
- The watch will search and connect to Wi-Fi
- Once connected, the device will display a message to Open Garmin Connect Mobile app to sign in. At the same time, your smartphone should display a notification similar to:
- Acknowledge message on the phone which will take you to Spotify. Enter your login details and select Log In.
Touchscreen Watches
Select Spotify
You will now be prompted to open the Garmin Connect app
From the Garmin Connect app, enter your Spotify login details and select LOG IN
Review and agree to the terms by selecting AGREE
Re-download music from Spotify
Note: Your watch must be able to connect to your Wi-Fi network to download content from Spotify. From your Spotify account, create playlists. Saved playlists will display as optional music to sync on your watch. For more information see Spotify Support.
Select Spotify
Select Add music & podcasts
Select Playlists
Choose playlists you want to sync to your watch.
Select Done
Press the Back button and select yes to “Start music sync now?”
At this point, the watch will attempt to connect to your Wi-Fi network. We recommend plugging the watch into a charger near the Wi-Fi router for the best results.
Touchscreen Watches
From your vivoactive 3 Music swipe your screen to the Music Widget
Select
(Spotify Icon)Select Add music & podcasts
Choose a category then choose the content you want to sync to your watch
If you continue to experience an issue, contact Product Support
