DC 30 Not Communicating with an Astro 220
If a DC™ 30 dog tracking collar is no longer communicating with an Astro® 220 dog tracking handheld, it is possible the collar software needs to be updated. Instructions for updating the DC 30 collar can be found in the related content below. If circumstances do not allow for an immediate update, the following steps can be used as a work around until the update can be performed.
Changing the Communication Settings:
  1. Press the DOG button
  2. Press the MENU button
  3. Select DOG LIST
  4. Select the name of your DC 30 from the list
  5. Select SHOW INFO
  6. Press MENU
  7. Select CHANGE COMM. SETTINGS
  8. Select OK
  9. Change the update rate to 5, 10, or 30 seconds
  10. Select OK
If the update rate was set to 0 seconds, changing it to 5, 10, or 30 seconds will allow the DC 30 collar to communicate consistently with the Astro 220 handheld.
Related
