Options Are Missing From the Main Menu on My Outdoor Handheld
The main menu or app drawer can be customized on outdoor handhelds to add or remove certain items. If there are items missing from the main menu or app drawer, they can be added by following the steps below. These are general steps that will apply to most devices. For more detailed instructions, refer to "Customizing the Main Menu" or "Customizing the App Drawer" in your owner's manual.
Touchscreen Devices
  1. Go the main menu.
  2. Tap 3 lines icon.
    • For devices that do not have this option, select Setup > Main Menu.
  3. Select Setup Drawer, or 3 lines icon > Setup Drawer.
  4. Select Add.
Non-Touchscreen Devices
NOTE: For some devices, if you add a page to the main page sequence, it no longer appears on the main menu. Refer to "Page Sequence Setup" or "Changing the Page Sequence" in your owner's manual for detailed instructions. For the Colorado® series outdoor handhelds, refer to "shortcuts" in your manual.
  1. Go to the main menu.
  2. Press Menu or select Edit.
  3. Select Change Item Order.
    • For eTrex® SE and Rino® 700 outdoor handheld, skip this step.
  4. Select + Add or Add Page.
