Viewing the Truck Profile
You can edit a vehicle profile to change vehicle information or add detailed information to a new vehicle profile, such as the vehicle identification number, trailer number, or odometer reading. The information found in the vehicle profile may also be requested for troubleshooting purposes.
See the Detailed Video Below for Instructions to Create a Vehicle Profile.
To Open or Edit the Vehicle Profile:
1. Touch Settings
2. Touch Vehicle Profile
3. Select the profile
4. Touch the wrench icon
You can View/Edit the Following Fields From This Screen:
  • Trailer Configuration: The number of semi-trailers attached to the truck tractor
    • Selecting zero indicates only a truck tractor (bobtail) is being driven with no trailer connected resting weight on the power unit and will not allow for some of the following profile settings to be entered.
    • Contact the FMCSA if there are questions regarding defining the configuration being carried by your specific vehicle.
  • Height: Measurement from the ground to the highest point on the tractor or trailer
  • Width: Measurement of the widest point of the tractor or trailer
  • Overall Length: Measurement of tractor and trailer from end to end combined
  • Gross Weight: Ensure the actual weight of the vehicle has been set for the gross and axle weight on the profile, and not the maximum possible weight of the vehicle
    • Setting the profile for the maximum possible weight may result in unneeded restrictions
  • Max Single Axle Weight:  dezl OTR Devices and Axle Weights
  • Max Tandem Axle Weight:  dezl OTR Devices and Axle Weights
  • Tandem Axle:  dezl OTR Devices and Axle Weights
  • Number of Axles: The total number of axles on the semi-trailer being pulled by the truck tractor
  • Max Speed: If you're governed by speed, enter your maximum speed to create a more realistic Estimated Time of Arrival
    • Setting the max speed may also adjust the routing course and provide additional route suggestions
  • Hazardous Materials: Articles or substances which can pose a risk to health, safety, property, or the environment
    • Contact the FMCSA if there are questions regarding defining the hazardous material being transported
  • Odometer: Miles on the tractor
  • Truck Type: The usage of the truck whether it is used for over the road service or deliveries
  • VIN: Vehicle VIN number
  • Vehicle Number: The number assigned to the semi-trailer being transported
