Purchase and Activate Traffic for the Suzuki Infotainment
With your Suzuki Infotainment system featuring Garmin navigation you can purchase an additional traffic subscription to provide unlimited access to traffic.  A traffic subscription will allow you to plan efficient routes and avoid traffic delays.
To purchase the traffic subscription, you will need a blank SD card between 8 GB and 32 GB in size. Once you have the SD card, you will need to prepare it to purchase the subscription. To do this, you will need to first go to the vehicle to create the update card.
To create the update card:
1. Insert the blank SD card into the radio
2. Touch Settings (wrench icon)
3. Touch System
4. Touch About
5. Touch Update
6. Touch OK when the update card is successfully created
7. Remove the SD card
Once you have created the update card, you will need to return to your computer and use our Garmin Express application to purchase the traffic subscription.
To purchase the traffic subscription:
1. Download and Install Garmin Express
2. Click Add a Device and follow prompts to add the device to Garmin Express
3. Click Store
4. Select your Country and click Continue
5. Click Real-time Traffic
6. Click the price button
7. Sign into your account or create an account and complete the purchase process
After completing the purchase process, you will be provided with two 25 character traffic subscription unlock codes. Write down or print the traffic subscription unlock codes. You will need to return to the vehicle and activate your traffic subscription with these codes.
To activate the traffic subscription:
1. Touch Settings (wrench icon)
2. Touch Traffic
3. Touch Disabled
4. Touch Enabled
5. Touch OK
6. Touch the add button (+ sign)
7. Touch Next
8. Enter the first 25 character unlock code
9. Touch Done
10. Enter the second 25 character unlock code
11. Touch Done
The traffic service is now activated and ready for use.
Related
