Steps to Link Your Garmin Connect Account with MyFitnessPal
Your Garmin Connect™ account can be linked to your MyFitnessPal account in order to sync calorie data, which can aid in reaching exercise and diet goals. To enable syncing, the two accounts must be linked through either Garmin Connect web or the Garmin Connect app.
The information below is communicated between MyFitnessPal and Garmin Connect:
  • Caloric intake that is input into MyFitnessPal will sync over to the Calories In/Out widget under the 'Consumed' category on Garmin Connect.
  • Manual activities created in MyFitnessPal are added as activities to Garmin Connect and will be added to the active calorie count on your Calorie In/Out widget.
  • Activities uploaded to Garmin Connect will show up in the MyFitnessPal News Feed and Diary as 'Exercise Calories'.
  • Weight added to Garmin Connect will sync to MyFitnessPal and vice versa.
  • Steps from Garmin Connect will sync to MyFitnessPal if you have selected Garmin Connect as your Steps device in MyFitnessPal.
    • If steps are not syncing see, .
For instructions to link your MyFitnessPal and Garmin Connect accounts, select an option below:
Garmin Connect Web
  1. Sign in to Garmin Connect.
  2. Select Health Stats in the expanded navigation bar on the left.
  3. Select Calories In/Out.
  4. Select Connect to MyFitnessPal.
  5. Select Agree.
  6. Enter Username/Password.
  7. Select Sign In.
It can take several minutes before the initial sync is complete. Both accounts will now sync calories burned and calories taken in.
Garmin Connect App
  1. Ensure that you have downloaded the MyFitnessPal app on your phone, created a MyFitnessPal account, and are logged in.
  2. Open the Garmin Connect app.
  3. Access the menu by selecting More (bottom right).
  4. Select Settings.
  5. Select Connected Apps.
  6. Select MyFitnessPal.
  7. Select Agree.
  8. Select Link Accounts.
  9. Select Allow.
Once the initial connection and sync are complete, both accounts will now sync calories burned and calories taken in.
