Languages Found on Golf Watches
Garmin golf watches are preloaded with several different languages, and can install others by using Garmin Express. Languages preinstalled to, and compatible with, outdoor watches vary by the region the watch was designed for. For instance, devices designed for Asian countries will typically support several Asian languages, where devices designed for the North American market may not support any Asian languages.
To determine what languages are already installed on your outdoor wearable, refer to the Language setting in your System settings. Searching your Owner's Manual for "language" will provide you steps for finding these settings on your watch.
Adding Languages with Garmin Express
Use these steps to add compatible languages to your watch.
  1. Plug your watch into a computer
  2. Open Garmin Express
    Note: If needed, install the Garmin Express program.
  3. Select or add your watch to Garmin Express
  4. Select Tools & Content
  5. Select Utilities
  6. Select Language Files under Optional Updates
  7. Check languages you would like to add
  8. Click Install Now
  9. Wait for the sync to complete
The selected languages are now available on your watch.
