Access Connect IQ App Settings With the Connect IQ Store App
Below are steps to access the settings of either a Connect IQ Watch Face, Device App, Data Field or Widget.
NOTE: Not all Connect IQ™ apps support setting changes.
  1. Open the Connect IQ Store app.
  2. Select  My Device.
    • If you have more than one Garmin device you can switch the device by selecting Three blue vertical dots then Select a Device.
  3. Depending on which Connect IQ app you would like to adjust, tap either My Watch Faces, My Device Apps, My Data Fields or My Widgets.
    • If any of the above Connect IQ features are missing, then they are not supported with your device.
  4. Select the app you would like to adjust.
  5. Select Settings.
  6. Select Save to send the changes to your Garmin device.
Related
