(2022) Service Bulletin 21116 Rev D: G1000 NXi STC Software Update v2286.14 for 200/300 Series Aircraft
PRODUCTS AFFECTED:
All Textron Aviation Inc. (Beechcraft) King Air 200 and 300 series aircraft equipped with G1000 Integrated Flight Deck per STC SA01535WI-D with system software versions 2286.06 through 2286.13 and equipped with all of the following LRUs:
  • GIA 64E
  • GMA 1360D
  • GEA 71B
  • GRS 7800/GDC 7400 or GSU 75B
CERTIFICATION AUTHORIZATION:
STC SA01535WI-D
COMPLIANCE:
Optional: This STC Service Bulletin may be incorporated at the owner’s discretion.
PURPOSE:
This service bulletin provides notification of an available update to System Software Version 2286.14 and includes the following changes:
NOTE
With this update, the ‘FDR with GIA64 Option’ configuration – intended to support a 3rd party FDR STC - was removed from the software image. In the future, a separate supplemental loader image will be created that contains the updated GIA 64 FDR configuration.
  • Support for -05 GEA™ 71B LRU (allows removal of existing Meggitt Signal Conditioners)
  • Support for -01 GTX™ 345R LRU (end-of-life planning only, no functional change)
  • Improvements to EIS transient indications for Prop RPM, Torque, and ITT
  • Addition of new features:
    • Standby Flight Plans
    • (Advisory) VNAV Guidance for Non-Precision Approaches
    • Fast Find
  • Support for direct (analog) interface to Collins ALT-50A or ALT-55B Radio Altimeter
  • GSU 75 software update to address susceptibility to reset in certain ground circumstances when operating without GPS aiding
  • GSA 9XXX software and Rudder Boost performance updates (300/B300 only)
  • Gain file updates for VNAV acknowledgment timeout and transition to approach force capture threshold improvements
