"No Detailed Maps Found That Support Routing" or "No Map Data Available" Message on a Garmin Automotive Device
There may be a problem with the mapping files if the message “No Detailed Maps Found That Support Routing” is displayed after turning on an automotive device. The message “No Map Data Available” may display when searching for a destination. This may cause the device to show only the locations of major cities or major highways with no side streets.
To Correct This Problem:
1. Touch Settings
2. Touch Map & Vehicle
3. Touch myMaps
4. Enable the maps
      • The map is enabled if a checkmark is present.
      • Touch the empty box if a checkmark is missing.
      • See the additional troubleshooting below if the map is missing or the page is blank.
Additional Troubleshooting if the Map is Missing from the Device or was Already Enabled:
  • Ensure the memory card is inserted and formatted properly if the maps were installed to a memory card.
    • See the detailed video for steps to properly insert the memory card:
See Formatting a microSD/SD Memory Card for instructions.
Safely remove your device from the computer after the update has completed. The write-caching feature on some computers may not have completely built or transferred the map to the device even though the update appears to be complete. Safely removing the device before unplugging it can prevent this problem from happening.
To Safely Remove the Device on Windows:
Note: The device can be unplugged normally if the screen shows the orange connection icon
Follow the below steps if the device shows the gray connection icon:
Windows 7/8
1. Click the triangle to show hidden icons
2. Right-click the Safely Remove Hardware icon
3. Click Eject GARMIN
4. Wait for Windows to display the message "Safe to Remove Hardware" before unplugging the device
Windows 10
1. Click the arrow to show hidden icons
To Safely Remove the Device on a Mac:
1. Open Finder
2. Click Go in the menu bar
3. Click Computer
4. Drag the Garmin device to the Trash to safely remove it
Contact Product Support for further assistance if the above does not resolve your issue.
See Maps Missing After Updating Maps on a Full Coverage Automotive Device for additional troubleshooting.
