How Does the Ambient Light Sensor Work on an Edge?
The ambient light sensor found on some Edge models works to provide the user with the right amount of backlight in order to view the screen depending on the lighting conditions they are riding in. The sensor also allows the backlight to automatically adjust which can conserve battery usage prolonging the time between charges. To change the brightness level manually or to adjust the auto brightness setting on the device you will need to access the system settings on the Edge. For specific details refer to your Owner's Manual.
