Understanding the LED Colors on the Garmin Dash Cam Mini
The Garmin Dash Cam™ Mini has a status LED light below the large save button that displays different colors depending on the device status. Below is a breakdown of the different LED meanings. Some colors can have more than one meaning
Green
  • The device is connected to a computer.
  • The memory card is being formatted.
  • If stuck on this color while plugged into the vehicle see Garmin Dash Cam Power Issues.
Green LED
Flashing Green
  • The device is booting.
 Booting LED
  • An update is being installed on software versions 7.10 and earlier.
Applying Update LED
  • An update is being installed on software versions 7.30 and later.
Applying Update LED
Red
  • Video is recording.
Recording Video LED
  •  Audio is being recorded.
Audio Recording LED
Flashing Red
  • A photo or video is starting to be saved.  The animation will play for 2 seconds.
  • An incident has been detected.
Saving Started
  • Saving a photo or video is in progress.  The animation will play for the duration of the save.
Saving
  • Parking Mode.
Parking Mode LED
Red with Flashing Yellow
Low on Space LED
See SD Memory Card Compatibility for the Garmin Dash Cam 46, Garmin Dash Cam 56, Garmin Dash Cam 66W, and Garmin Dash Cam Mini to ensure a compatible card is being used.
See the owner's manual or Formatting a microSD card on a Garmin Dash Cam Mini for instructions to format the memory card and update the software.
Flashing Yellow/Flashing Yellow and Green
  •  There is a problem with the memory card.
Flashing Yellow LED
See Flashing Yellow/Yellow and Green Light on a Garmin Dash Cam Mini for troubleshooting steps.
Blue/Flashing Blue and Red
  • The device is in Wi-Fi sharing mode.
 Blue LED Wi-Fi
  •  The device is in Bluetooth pairing mode (recording audio).
 Recording Audio LED
  •  The device is in Bluetooth pairing mode (not recording audio).
Not recording audio LED
No Light
  • The camera is not connected to a power source.
No LED
