Alpha® 100 | Alpha® 10
Alpha® 200 | Alpha® 200i
Alpha® 300 | Alpha® 300i
Astro® 220 | Astro® 320 | Astro® 430 | Astro® 900
Colorado® 300
Colorado® 400c | Colorado® 400i | Colorado® 400t
Dakota® 20
eTrex® 30 | eTrex® 30x |eTrex® 32x
eTrex® Summit | eTrex® Summit HC
eTrex® Touch 25 | eTrex® Touch 35 | eTrex® Touch 35t
eTrex® Vista | eTrex® Vista C |eTrex® Vista CX | eTrex® Vista H | eTrex® Vista HCx
Foretrex® 401 |Foretrex® 601 | Foretrex® 801
Foretrex® 701 Ballistic Edition | Foretrex® 901 Ballistic Edition
Geko™ 301
GPSMAP® 276Cx
GPSMAP® 62s |GPSMAP® 62sc | GPSMAP® 62st |GPSMAP® 62stc
GPSMAP® 64csx | GPSMAP® 64s |GPSMAP® 64st |GPSMAP® 64sx
GPSMAP® 65s
GPSMAP® 66 | GPSMAP® 66i |GPSMAP® 66s | GPSMAP® 66s | GPSMAP® 66sr | GPSMAP® 66st
GPSMAP® 67 | GPSMAP® 67i
GPSMAP® 76CS |GPSMAP® 76CS | GPSMAP® 76CSx |GPSMAP® 76S
GPSMAP® 78s | GPSMAP® 78sc
Montana® 600 outdoor handheld and all other models in the Montana® 600 series
Montana® 700 outdoor handheld and all other models in the Montana® 700 series
Monterra®
Oregon® 300
Oregon® 400c | Oregon® 400t
Oregon® 450 | Oregon® 450t
Oregon® 550
Oregon® 600 | Oregon® 600t
Oregon® 650 | Oregon® 650t
Oregon® 700
Oregon® 750 | Oregon® 750t
Rino® 530 | Rino® 530HCx
Rino® 650 | Rino® 650t | Rino® 655t
Rino® 750 | Rino® 755t
Elevation Accuracy of Outdoor and Fitness Devices
Barometric Altimeter Accuracy
With proper calibration, the barometric altimeter of a Garmin watch or outdoor handheld will report elevation readings ranging from -2,000 to 30,000 feet with an accuracy of +/-10 feet. Elevation values greater than 30,000 feet can be generated, but may not be accurate due to environmental factors.
NOTE: Garmin fitness and outdoor products are designed as recreational GPS devices to be used as aids in navigation. They should not be used for any activity requiring precise measurements, such as surveying or weather prediction.
D2™ Air | D2™ Air X10
Descent™ G1 | Descent™ G1 Solar
Descent™ Mk1
Descent™ Mk2 | Descent™ Mk2S | Descent™ Mk2i
epix™
epix™ (gen 2) Standard Edition | epix™ (gen 2) Porche Edition | epix™ (Gen 2) Sapphire Edition
fēnix® 3 | fēnix® 3 HR | fēnix® 3 Sapphire
fēnix® 5 Standard Edition watch and all other models in the fēnix 5 series
fēnix® 6 Standard Edition watch and all other models in the fēnix 6 series
fēnix® 7 Standard Edition watch and all other models in the fēnix 7 series
fēnix® 7 Pro Solar Edition watch and all other models in the fēnix 7 series
Forerunner® 255 | Forerunner® 255 Music | Forerunner® 255S | Forerunner® 255S Music
Forerunner® 265 | Forerunner® 265S
Forerunner® 645 | Forerunner® 645 Music
Forerunner® 745
Forerunner® 910 XT
Forerunner® 920 XT
Forerunner® 935
Forerunner® 945 | Forerunner® 945 LTE
Forerunner® 955 | Forerunner® 955 Solar
Forerunner® 965
Instinct® – Standard Edition | Instinct® – Esports Edition | Instinct® – Tactical Edition
Instinct® Solar – Camo Edition | Instinct® Solar – Surf Edition
Instinct® 2 Standard Edition watch and all other models in the Instinct 2 series
Instinct® 2 Solar watch and all other models in the Instinct 2 Solar series
MARQ® Adventurer and all other models in the MARQ collection
MARQ® Adventurer (Gen 2) and all other models in the MARQ (Gen 2) collection
tactix® Bravo | tactix® Charlie
tactix® Delta – Sapphire Edition | tactix® Delta - Solar Edition | tactix® Solar Edition with Ballistics
tactix® 7 Standard Edition | tactix® 7 Pro Edition | tactix® 7 Pro Ballistics Edition
Venu®
Venu® 2 | Venu® 2S
Venu® 2 Plus
Venu® 3 | Venu® 3S
vívoactive® HR
vívoactive® 3 | vívoactive® 3 Music
vívoactive® 4 | vívoactive® 4S
vívomove® HR
vívomove® 3 | vívomove® 3S
vívomove® Luxe | vívomove® Style | vívomove® Trend
vívosmart® HR watch | vívosmart® HR+
vívosmart® 3
vívosmart® 4
vívosmart® 5
vívosport®
Factors Affecting Barometric Altimeter Accuracy
Accuracy of GPS Elevation
Elevation calibrated by GPS is accurate to +/-400 feet with a strong GPS signal. Elevation is determined by the device acquiring a GPS signal, while maps will provide elevation information based on survey data. GPS elevation readings may be different than elevations on maps or marked on trails and roads.
