zūmo® XT and zūmo® XT2 GPS navigators SD Card Not Detected, Recognized, or Incompatible in Garmin Express
Garmin Express may display an SD card as incompatible or fail to detect the SD card if there is a problem with the card or the computer's USB configuration.
  1. Ensure Garmin Express is up to date.
  2. Make sure the SD card is fully inserted. The brass pins should be fully covered by the card. Garmin Express will not work with a separate memory card reader.
    See the detailed video below for instructions to insert a memory card
  3. Make sure the USB is plugged directly into the device and computer:
    • Do not use a USB hub or extension cable.
    • Use the USB ports on the back of the desktop computer.
  4. Unplug all USB devices (except for the mouse and keyboard), reboot the computer, and connect again.
  5. Try a different USB port on the computer.
  6. Format the memory card
  7. Try using a different SD card.
  8. Run Garmin Express as an administrator.
  9. Run Garmin Express on a different computer.
    • If using a Mac computer, you can try a different Admin User before trying another computer.
    • Contact Apple for instructions.
A functioning SD card should be detected if these troubleshooting steps are taken.
Related
