zumo 590 and zumo 595 has no audio from line-in through a Bluetooth headset
If you are using a wired connection to an audio source (such as your phone via the headphone jack for the device, or using an Aux cable from the motorcycle's audio system) and have a Bluetooth headset paired to the zumo, the audio being played from the line-in source may not be heard through the headset. Resetting the media source can correct this issue.
To reset the media source:
  1. Touch Apps on the main menu
  2. Touch Media Player
  3. Touch the Media Source button
    • This is the icon of two audio plugs in the top-left corner of the screen
  4. Select a different media source1
  5. Touch Save
  6. Touch the Media Source button
  7. Select Line In
  8. Touch Save
Audio should now be played through the Bluetooth headset.
1Information on the different media source options and what they are used for can be found in Related Content.
Related
