Editing Reps on Outdoor Multisport Watches
Using the rep count feature on a compatible outdoor wearable will allow the user to track common gym exercises and count the number of reps completed. The devices use consistent motion to categorize exercises and display reps on the device.
Since each person’s form and exercise cadence is different, it is possible that the device may miss or count extra reps. In these situations, the band allows for the number of reps to be edited during rests between sets.
Editing Rep Count
Start a Strength activity.
Complete a set of reps.
Press BACK.
Press DOWN to access Edit.
NOTE: Press and hold MENU if you missed the Edit option. You will then have the option to Edit Last Set.
Press UP or DOWN to add or remove reps.
Press START/STOP.
Press UP or DOWN to add or remove weight.
Press START/STOP to resume your rest period.
Press BACK to end your rest and begin your next set.
Repeat steps for each set as needed.
These steps will ensure that the correct number of reps are displayed on the device and are synced to Garmin Connect. The number of reps per set can also be edited in Garmin Connect after the activity is synced.
NOTE: While tracking a Strength Training exercise, it is common for the device to not display any reps counted until the device tracks up to 5 reps. In this situation, the watch will display “—“ until the device recognizes between 3-5 reps.
