Garmin Catalyst Remote Cam Not Recording or Missing Video
Follow the Steps Below if Video Footage or Drive Session Data Cannot be Found on your Garmin Catalyst™ Driving Performance Optimizer or the Device's SD Card:
  1. Ensure the Garmin Catalyst and Remote Cam are powered properly
  2. Ensure the device is recording video
  3. Check SD card compatibility
  4. Ensure the device is up to date
  5. Format or replace the SD card
Ensure the Garmin Catalyst and Remote Cam are Powered Properly
NOTE: Avoid using 3D printed mounts
Ensure the Device is Recording Video
  • Make sure the SD card is inserted all the way into the Garmin Catalyst.
    • It is easiest to use a fingernail to press the SD card into the slot under the back panel or side of the unit until a click is heard.
  • Ensure the Remote Cam is plugged in with the included camera cable (longer 11.5 foot cable) and the LED at the bottom of the Remote Cam glows a solid red.
    • Using any other USB cable could cause power issues and prevent the video data from being sent to the memory card.
    • The shorter cable is for data transfer on a computer.
    • See the video below for instructions to properly install the Garmin Catalyst and Remote Cam.
  • Ensure you are using the included Remote Cam to record video. The Garmin Dash Cam Mini and Garmin Dash Cam Mini 2 are not compatible.
Check SD Card Compatibility
Ensure the Device is Up to Date
Format or Replace the SD Card
Contact Product Support if the Garmin Catalyst Remote Cam still fails to record any video.
