Garmin Marine Network Sharing Compatibility
Below is a breakdown of the Garmin marine device's ability to transmit and receive information across the Garmin Marine Network. It refers to the built-in functions and features of the chartplotter. It does not include external devices such as radar, sonar modules (GSD, GLS, or GCV), or SiriusXM antennas.
The chartplotters listed will only share with other devices within the same table.
The GCV 10, GCV 20, and GMS 10 have additional Garmin Marine Network ports and will act as a network hub between compatible chartplotters.
For external component sharing capabilities, see External Devices Sharing Over the Garmin Marine Network.
ECHOMAP Series
Device | Built-In Sonar | Preloaded Charts | Supplemental Charts | User Data | Quickdraw Contours |
ECHOMAP Plus 7x / 9x* | ✔ | ✔ | ✔ | ✔ | ✔ |
ECHOMAP Ultra Series | ✔ | ✔ | ✔ | ✔ | ✔ |
ECHOMAP UHD 7x / 9x | ✔ | ✔ | ✔ | ✔ | ✔ |
ECHOMAP UHD2 Series** | ✔ | ✔ | ✔ | ✔ | ✔ |
* The Marine network sharing port was unlocked to allow data sharing after software version 6.20. To verify the software version Select Settings > System > System Information > Software information.
** Not all ECHOMAP UHD2 devices have a Marine Network port.
GPSMAP 3000 Series
Device | Preloaded Charts | Supplemental Charts | User Data |
GPSMAP 3000 | ✔ | ✔ | ✔1 |
1User Data transferred over the network must be manually initiated.
GPSMAP 4000/5000/6000/7000/8000 Series
GPSMAP 40xx / 42xx | ✔ | ✔ | ✔1 |
GPSMAP 50xx / 52xx | ✔ | ✔ | ✔1 |
GPSMAP 60xx / 62xx | ✔ | ✔ | ✔1 |
GPSMAP 70xx / 72xx | ✔ | ✔ | ✔1 |
GPSMAP 80XX / 8200 / 85xx | ✔ | ✔ | ✔ |
Black GPSMAP Series and Legacy echoMAP 70s/DV
echoMAP 70s / 70dv | ✔ | X | X | ✔2 | ✔ |
GPSMAP 5x7 | ✔ | X | X | ✔2 | ✔ |
GPSMAP 7x1 / 8x0 / 10x0 | ✔ | ✔ | ✔ | ✔2 | ✔ |
GPSMAP 7x2 / 9x2 / 10x2** / 12x2** | ✔ | ✔ | ✔ | ✔ | ✔ |
GPSMAP 7x3 / 9x3 / 12x3** | ✔* | ✔ | ✔ | ✔ | ✔ |
GPSMAP 74xx / 76xx | ✔ | ✔ | ✔ | ✔ | ✔ |
GPSMAP 84xx / 86xx / 87xx** | ✔* | ✔ | ✔ | ✔ | ✔ |
2User data sharing is only compatible with other devices marked with "✔2."
* The GPSMAP 84xx / 86xx / 87xx and the GPSMAP 7x3 / 9x3 / 12x3 series can only share their sonar with other 8xxx Series (any generation), 74xx / 76xx series, GPSMAP 7x2 / 9x2 / 10x2 / 12x2 series and the GPSMAP 7x3 / 9x3 / 12x3
** Chartplotters with built-in Garmin Navionics+ cannot utilize BlueChart g3 supplemental charts.
Examples of Networking Incompatibility
ECHOMAP device cannot share any data with a GPSMAP device
Devices preloaded with charts, including Garmin Navionics+ charts, will not share their preloaded content to networked devices unless the other devices do not have preloaded maps. For example, ECHOMAP Plus 94sv will not share preloaded BlueChart maps with an ECHOMAP UHD 73cv, preloaded with LakeVu maps. However, it will share the preloaded map with an ECHOMAP Plus 72cv, which only has a base map
Sharing supplemental Garmin Navionics+ content from a card can only be done from a chartplotter that supports Garmin Navionics+ to another chartplotter that supports Garmin Navionics+
A chartplotter connected to a UHD transducer can share its sonar with a non-UHD compatible chartplotter. However, the sonar will present itself as if it were coming from a non-UHD transducer
Legacy GPSMAP devices do not share data through Marine Network with current model GPSMAP units
