Pairing Garmin HUD/HUD+ with a Smartphone
Before you can use the Garmin HUD/HUD+ with your Smartphone and Garmin navigation application, the HUD/HUD+ must be connected via Bluetooth, and enabled in the application. Once you pair the HUD/HUD+, the application should automatically enable HUD support.
Follow the Steps Below:
  1. Using the provided power cable, plug the Garmin HUD/HUD+ into your vehicle's 12 volt power outlet.
  2. Turn on the HUD/HUD+ and wait for the word "PAIR" to appear on the display.
    • If you don't see this, press and hold the Power Button on the HUD/HUD+ for three (3) seconds to turn it On.
  3. Ensure that the HUD/HUD+ and Smartphone are within 33ft (10m) of each other.
  4. Enable Bluetooth on your Smartphone and Search for devices. A list of nearby Bluetooth devices should appear.
    • If you are unsure on how to do this, please see the Owner's Manual of your Smartphone.
  5. Select the Garmin HUD/HUD+ to Connect and Pair the two devices.
If automatic detection of paired devices is enabled on your Smartphone, the Garmin HUD/HUD+ should automatically connect if both are in range of one another and powered on. You may be prompted to allow pairing. If you only see a line of dashes, you may have to enable HUD support in the application itself. To enable HUD support, follow the steps below for your Smartphone and application:
iOS Devices:
  • Navigon
    1. Touch 'Settings'
    2. Touch 'General'
    3. Scroll to bottom and touch 'Garmin HUD'
    4. Touch 'Garmin HUD Support'
    5. Be sure there is a check mark by ‘On’, if not touch ‘On’
  • Viago
    1. Touch the menu icon (triangle)
    2. Touch 'Settings'
    3. Touch 'General'
    4. Touch 'Garmin HUD'
    5. The toggle switch should be to the right, if is not then slide it to the right
  • Garmin StreetPilot®
    1. Touch 'Settings'
    2. Touch 'Audio and Display'
    4. The toggle switch should be to the right, if is not then slide it to the right
  • Garmin HUD app (This app can be used only with the Garmin HUD+ head-up display, NOT with the standard Garmin HUD device)
    • The HUD+ must be paired to the phone prior opening the app.
    • After the first connection, and each subsequent connection, to your HUD+ device this app can be used without the HUD+ device for up to 30 days. To continue using after 30 days, simply re-pair with your Garmin HUD+.
Android Devices:
  • Navigon
    1. Touch 'Settings'
    2. Touch 'Garmin HUD'
    3. Make sure there is a check in HUD support
  • Viago
    1. Touch 'Settings'
    2. Touch 'General'
    3. Touch 'Garmin HUD'
    4. Make sure there is a check in Garmin HUD support
Windows Device:
  • Navigon:
    1. Touch 'Settings'
    3. Make sure the slider is set to ‘On’ under Status, if not slide it to ‘On’
If you are still experiencing pairing issues, contact Garmin Customer Support.
Effective May 14, 2018 Garmin StreetPilot® for iOS and Navigon apps are no longer available for purchase or download.
