Using Map Manager on Garmin Approach Golf Watches
The following Garmin™ Approach® golf watches have a Map Manager feature that allows you to update CourseView maps directly from the watch:
Approach® S70 - 42mm
- Approach® S70 - 47mm
When your watch is connected to a , you can download available map updates.
Garmin Express™ can also be used to manage and download maps. For more information, see Related content below.
Using the Map Manager
NOTE: Downloading maps over Wi-Fi can drain the battery, and download times can vary depending on the size of the map and your internet connection. The watch queues the map download for later, and the download starts when you connect the watch to a wall AC adapter. Connecting to a computer USB will not start the download.
Press
Tap Settings.
Tap System.
Tap Map Manager.
Tap Check for Updates
Select a CourseView Map.
Press the Action Button to open the menu.
Tap Update.
