Setting Up Smartphone Link Traffic on an iPhone
Live traffic information can be received through your compatible smartphone's data plan and can be sent instantaneously to your Garmin automotive navigator through the free Smartphone Link App. This information allows your Garmin device to display and help you avoid slow traffic due to accidents, construction, or other obstacles.
See below for a video tutorial on setting up Smartphone Link Traffic on your iPhone.
Installing Smartphone Link
First, it is necessary to verify your smartphone is compatible with Smartphone Link. For information on compatible mobile platforms and automotive devices, see the FAQ Smartphone Link Compatibility and Availability.
Once you have confirmed that your phone and automotive device are able to communicate via Smartphone Link, the next step is to download the App to your phone. For steps, see the FAQ Installing Garmin Smartphone Link.
Pairing Smartphone Link with the Automotive Device
Once the App has been installed to your phone, Smartphone Link and the automotive device are ready to be paired, if they have not been already.
To Pair Smartphone Link and your Automotive Device, on the Automotive Device:
- Touch Settings
- Touch Bluetooth or Wireless Networks
- Check the box next to Bluetooth, if no checkmark is present
- Touch Add Phone or Scan for Devices
- Place your phone in Discoverable/Find Me mode, and then touch OK on the message prompting you to do so on the Garmin device
- Instructions for this should be found in your manual/documentation for your smartphone
- Touch the name of the desired phone from the list of compatible Bluetooth devices in the area
- Touch OK
- A message should display that the Garmin device successfully paired with the phone
- Open the Smartphone Link App on your phone
- A security code will appear on the screen of the automotive device. Enter the code into your phone within 30 seconds of the prompt appearing.
Confirming Traffic Service
After your device and phone have been connected via Smartphone Link, live traffic service should begin automatically.
To Confirm That you are Receiving Traffic from Smartphone Link, on your Automotive Device:
- Touch Settings
- Touch Traffic
- Check the listing for Current Provider
Here, Smartphone Link should be listed.
