The Touchscreen of My Garmin Outdoor Handheld is Not Working
If you are experiencing any of the following symptoms with your touchscreen handheld, a screen calibration may be needed.
- Unable to select menu items
- Opening the wrong menu items
- Cannot select items around the edge of the touchscreen
- Cannot accurately select a position on the map
- Area under your finger is not selected when using the touchscreen
Calibrating the Touchscreen
If the touchscreen on your outdoor handheld is inaccurate or not responding, then a calibration should be performed. There are two ways to calibrate the touchscreen depending on how it is responding.
Responsive Touchscreen
- From the main menu, touch Setup.
- Touch Display.
- Touch Calibrate Screen.
- Touch each dot as they appear.
- Touch OK once the Calibration Complete message appears.
Unresponsive Touchscreen
If the touchscreen is completely inoperable, you may need to manually calibrate the touchscreen.
- Power the device off.
- Press and hold the Power button until Press the dot message appears (about 60 seconds).
The touchscreen is now calibrated and should function properly.
