Using the HRM-Pro/Pro Plus Running Pace and Distance Feature
The HRM-Pro/Pro Plus can calculate running pace and distance based on your user profile and the motion measured by the sensor on every stride. By default, the HRM-Pro/Pro Plus provides running pace and distance when GPS is not available, such as during treadmill running or if you lose GPS when running outdoors. You can view your running pace and distance on your watch when connected via ANT+. Using the strap with a compatible third-party training app requires you to pair it using Bluetooth.
NOTE: To get pace and distance, a compatible watch must be paired and in range of the HRM-Pro/Pro Plus strap during the activity. For troubleshooting steps see: HRM-Pro/Pro Plus Running Pace and Distance Troubleshooting Tips.
Compatible Watch List
NOTE: Ensure your watch is running the latest software to see the running pace and distance feature from the HRM-Pro/Pro Plus.
  • Enduro Series
  • Enduro 2
  • epix (Gen 2)
  • fēnix 6 Series
  • fēnix 7 Series
  • Forerunner 55
  • Forerunner 255 Series
  • Forerunner 265 Series
  • Forerunner 745
  • Forerunner 945 Series
  • Forerunner 955 Series
  • Forerunner 965
  • Instinct 2 Series
  • Instinct Crossover Series
  • MARQ Collection
  • MARQ Collection (Gen 2)
  • tactix Delta Series
  • tactix 7 Series
You can access settings relating to running pace and distance by selecting your heart rate strap from the list of paired sensors and accessories in the menu of the watch. To access the sensor settings:
  1. Put on the heart rate monitor.
  2. Press and hold the Menu button of the watch.
  3. Scroll and select Sensors & Accessories.
  4. Select HRM-Pro or HRM-Pro Plus.
  5. Select HRM Pace & Distance to adjust settings.
I Do Not Have A Compatible Watch
If your watch is not listed above, but is compatible with a foot pod and heart rate sensor, you can still use the strap to record pace and distance. The watch will see the HRM-Pro/Pro Plus as two separate sensors, a heart rate monitor and a foot pod. You will need to pair both sensor types for the feature to function on your watch.
NOTE: Watches that feature a treadmill calibration option will lose this feature when you add the HRM-Pro/Pro Plus as a foot pod sensor. You will be required to calibrate distance from the foot pod sensor settings. For information on how to calibrate a foot pod sensor, see: How Do I Calibrate the Foot Pod?
Example of Sensor Pairing Process
Screenshot of watch screen showing sensor found information.Screenshot of watch showing user adding sensor
Connection Status of Sensor
Screenshot of what showing sensor as connected.
Connected Sensor Icons From Activity Data Screen
Screenshot of watch showing what sensors are connected as well as GPS being locked on.
Related
