How to Customize the Garmin Boat Switch Page
You can customize the Garmin Boat Switch page in multiple ways. Follow the steps below to customize each aspect of the page:
Configuring Switch Names
- From a Garmin chartplotter connected to the same NMEA 2000 network as the Garmin Boat Switch device, select > Options> Settings> My Vessel> Switching> NMEA Standard.
- Select the desired switch number.
- Select Name> Edit Name.
- Enter a new name.
- Select Done.
Configuring Switch Labels
- Select Label> Edit Label.
- Select Done.
Configuring Switch Visibility
- Select Visibility to show or hide the switch.
Configuring Momentary/Latching Switches
- Select Configuration.
- Select Momentary or Latching.
Changing the Switch Style
- From the Garmin chartplotter's Boat Switch page, select > Options> Switch Style.
- Select the desired switch style from the options: Rocker Switch, Silver Push Switch or Black Push Switch.
Adding a BoatView Image
- From the Garmin chartplotter's Boat Switch page, select > Options> Setup> Edit Page> Add BoatView Image
- Press the Boat Image button to set to Show.
- Press the Orientation button to switch between Vertical or Horizontal.
- Select Change Image to choose a preconfigured model or upload an image from a SD card.
Note: When choosing a custom BoatView image the file can be in .jpg, .png or .bmp. Please refer to the Garmin chartplotter's Owner's Manual for image size requirements.
Adding Icons to Switches
- Follow the instructions to add a BoatView image
- From the Boat Switch page select Options>Setup>Edit Page>Place Switches>Change Icon
- Select the switch from the list
- Choose the desired icon, the icon will appear in the list next to the switch under Icon
