You are viewing an article that is not available in your currently selected language. You can choose another one below.
Determining if a Garmin Chartplotter is Receiving NMEA 0183 Data
To determine if NMEA 0183 data is being received by a Garmin chartplotter, Garmin has added a diagnostic into newer devices to show which NMEA 0183 sentences are being received at the time.
This feature will work on the following devices:
  • GPSMAP® 7x3 chartplotters
  • GPSMAP® 9x3 chartplotters
  • GPSMAP® 1xx2 chartplotters
  • GPSMAP® 12x3 chartplotters
  • GPSMAP® 16x3 chartplotters
  • GPSMAP® 74xx chartplotters | GPSMAP® 76xx chartplotters
  • GPSMAP® 84xx chartplotters | GPSMAP® 86xx chartplotters
  • GPSMAP® 90xx chartplotters | GPSMAP® 92xx chartplotters
  • ECHOMAP™ PLUS chartplotters |ECHOMAP™ UHD chartplotters | ECHOMAP™ UHD2 chartplotters | ECHOMAP™ Ultra chartplotters | ECHOMAP™ Ultra 2 chartplotters
To view the NMEA 0183 diagnostics, please follow these instructions:
On a GPSMAP: From any screen Options > Settings > Communications > NMEA 0183 Setup > Diagnostics
On an ECHOMAP go to Home > Settings > Communications > NMEA 0183 Setup > Diagnostics
The screen will now display a list of NMEA 0183 sentences that can be received by the device. This screen will also show the status of whether the sentence has been received or not.
