APPROACH CT10 - Pairing Your Watch
Before you can record shots, you must pair your Approach CT10 sensors with a compatible Garmin golf watch, and assign sensors to your clubs.
NOTE: You may need to update the software on your watch before pairing your sensors.
  1. Attach all sensors to your clubs
  2. Take a club out of your golf bag.
    You should keep all of the other clubs in your golf bag while pairing.
    TIP: You should complete the pairing process in a well-lit room. The sensors automatically wake up based on the ambient light.
  3. Bring the club within 1 m (3 ft.) of your watch.
    NOTE: The grip should be pointed up.
  4. From the watch settings, select Club Sensors > Add New.
    The watch begins searching for the sensor. A message appears when the sensor is detected.
  5. Follow the on-screen instructions to pair your watch with the club you removed from the bag.
    A message appears when the sensor is assigned.
  6. Return the club to your golf bag.
  7. Take out the next club from your golf bag.
  8. Repeat steps 5 through 7 until all of the sensors have been assigned to your clubs.
