Editing AutoShot Information With the Garmin Golf App
The Garmin Golf™ app allows you to edit the shot location, edit the club used, type of shot, lay of the ball, and remove shots recorded with the Garmin AutoShot™ feature.
When reviewing and editing shots, the type of shot is indicated by the colored dot with the yardage next to it.
Yellow - Tee Shot
White - Drive Shot
Blue - Approach Shot
Editing Shots
This allows you to edit the club used, mark a shot out of bounds, or delete a shot.
Open the Garmin Golf app.
Select (Android only).
Select Scorecards.
Select a scorecard.
Select a hole from the AutoShot list below the scorecard.
Touch a shot to edit.
Make necessary changes on the popup box.
Select Done.
Adding Shots
This can be useful if a shot was not detected by your device during the round.
Select Scorecards.
Select a scorecard.
Select .
Touch location on hole map where you want to place the shot.
Add additional information such as the club used on the popup box.
Select Done.
See Related for more information on the AutoShot feature.
