Disabling Kaspersky Antivirus and Firewall Protection
By default, Kaspersky Firewall is enabled and functions in the optimal mode. If needed, you can disable Kaspersky Firewall.
To disable Kaspersky antivirus and firewall protection on your computer due to an error in the Chart Installer program, do the following:
- Right-click the Kaspersky icon in the System Tray. This is located in the lower-right corner of the desktop. The icon looks like a K.
If you do not see the icon, click the arrow button at the edge of the System Tray to expand the Tray and display all the icons.
Open the application Settings window.
- In the main application window -
- Select the Settings tab.
or - In the context menu of the application icon, select Settings.
- In the left part of the window, the settings of the Kaspersky Firewall component are displayed.
- To enable Kaspersky Firewall, select the Enable Firewall check box.
- To disable Kaspersky Firewall, deselect the Enable Firewall check box.
- To save changes, click the Save button.
Close the Chart Installer program and then reopen it to refresh the screen and proceed to start the download again.
