Changing the Text Language on an Automotive Device if you can't Read it
You can change the text language if a device is in a language you cannot read (wrong language).
To Change the Text Language:
When the device is first powered on an agreement screen will appear briefly. Select the button at the bottom.
If the device is in Camper/RV or Truck profile mode you may need to select the vehicle profile.
1. Touch the Gear icon on the screen with the trucks at a loading dock and map icons
2. Touch the down arrow twice
3. Touch the globe icon
4. Touch the second option from the top
5. Touch the up or down arrow until you find the desired language
6. Touch the desired language to select it
7. Touch the lower right-hand button to Save
The device should now be in the selected text language.
See your owner's manual for instructions on changing your device's keyboard or voice language(s).
