Fusion Apollo MS-RA770 Manual Software Updates
Fusion Apollo RA770 software version 6.10.167
as of September 11, 2023
Download (150.89 MB)
View installation instructions
Notes:
- This firmware release also contains updates for DAB+ accessories and NRX remote controls.
- NRX Series Remote 1.02.79
- DAB+ Module 1.06
- DAB+ Tuner 6.06
- USB Flash Drive: Ensure the USB Flash Drive is formatted to FAT32.
- Accessory software updates (MS-NRX Series/MS-DAB100A): Once the stereo is updated the connected accessory MUST be updated from the update menu to be compatible with your Fusion Entertainment System.
- PartyBus-Network Compatibility: All Apollo stereos must be updated to the latest version for the PartyBus-Network feature to function correctly.
Change History
Changes made from version 6.00 to 6.10:
- User interface performance improvements
Changes made from version 5.90 to 6.00:
- Changes to the way radio presets are displayed for AM, FM & DAB. Station names are now included.
- Other bug fixes and improvements.
Changes made from version 5.80 to 5.90:
- General improvements and bug fixes.
Changes made from version 5.70 to 5.80:
Changes made from version 5.50 to 5.70:
- Updated loudness curves.
- Updated splash screens.
- Added zone and device name suggestions.
- Added confirmation when deleting presets.
- Modified volume limit display.
Changes made from version 5.40 to 5.50:
- Added Group Sync power option.
- Added Power Synchronization feature.
Changes made from version 5.10 to 5.40:
- Added NMEA 2000 Speed vs Volume feature.
- Added Keep Volume ratios.
- Added Mono Audio setting.
- Added Zone Gain setting.
- Adjusted sub-woofer volume curve.
- Added crossover enabled DSP setting.
Changes made from version 5.00 to 5.10:
- Bluetooth source improvements.
Installation Instructions
- Download the update file to your PC/Laptop.
- Extract the zip file to a USB flash drive (format FAT32). A folder named Garmin will be created on the flash drive.
- Connect the USB Flash Drive to the USB Port of the stereo.
- Go to the settings menu and select >Update>Stereo and confirm Yes. The update will run and the stereo will reboot when complete.
- The accessories DAB+ and NRX remote can now be updated from the update menu if required.
