Changing Automotive Devices Vehicle Type or Usage Mode
The vehicle type determines how the device will calculate routes. View the list at the bottom of this article for details on how each of these vehicle types works.
To Change the Vehicle Type:
- Touch the vehicle type icon at the top of the main menu
- Touch the desired vehicle type
- Touch Save or OK to save the change
Repeat the steps above to change the vehicle type again.
The Usage Mode refers to different routes the device can create based on your vehicle type.
Vehicle Types and Usage Modes:
- Automobile: This is the most-used setting that will give you turn by turn directions based on mapping and road information.
- Pedestrian: This mode is used when you are walking and will avoid highways. This setting will also keep you away from larger roads and will prefer smaller side streets.
