Pair the BC 20 Wireless Backup Camera Transmitter and the Device Mount
The BC 20 wireless transmitter and the included mounting bracket (used with a compatible navigation device) come paired out of the box.
Note: You must use the mounting bracket included with the BC 20.  The mount originally included with the compatible navigation device will not receive a wireless video signal from the BC 20.
Once installed, no special steps should be required for the two to pair.
A Detailed Video Tutorial is Available Below:
This is a quick and easy way to learn how to pair your transmitter and mount.
Re-Pair Them if the Transmitter and the Mounting Bracket are Properly Installed but You Are Not Receiving Video Signal:
  1. Verify there is no power to the transmitter by placing the vehicle in park or turning off the applicable steady power source
  2. Turn on the compatible navigation device (e.g., RV 760)
  3. Hold the pairing button on the back of the GPS navigation device's mounting bracket until Start Pairing appears on the device's screen
    • Make sure the mounting bracket is correctly connected to power if Start Pairing does not appear on the device
  4. Apply power to the transmitter by placing the vehicle in reverse or turning on the applicable steady power source
    • Pairing OK appears on the device after about five seconds
  5. Repeat step one to remove power from both the mounting bracket and the transmitter
  6. Restore power to both the mounting bracket and the transmitter
The transmitter and the mount should now be paired. If not, repeat these steps.
See BC 20 Wireless Backup Camera isn't Working Properly for more troubleshooting.
